prometa.git.gitlab.ci package
Subpackages
Submodules
prometa.git.gitlab.ci.ci_job_manager module
Base class for each CI job manager.
class prometa.git.gitlab.ci.ci_job_manager.CIJobManager(gitlab_ci)[source]
Bases: Registrable
Registrable base class for each CI job manager.
NAME = None[source]
__init__(gitlab_ci)[source]
Parameters:
gitlab_ci – A GitLabCI instance.
property enabled[source]
The job’s name is in the gitlab.enabled_ci_jobs list in the configuration file.
manage()[source]
Manage the job in the CI file according to current project conditions and configuration settings.
prometa.git.gitlab.ci.pages module
Manage the pages job.
class prometa.git.gitlab.ci.pages.PagesCIJobManager(gitlab_ci)[source]
Bases: CIJobManager
This does not create the pages job. It only updates it to set the following fields: “artifacts”, “only” and “stage”.
NAME = 'pages'[source]
manage()[source]
prometa.git.gitlab.ci.release_job module
Manage the release_job job.
class prometa.git.gitlab.ci.release_job.ReleaseJobCIJobManager(gitlab_ci)[source]
Bases: CIJobManager
Add a release job that triggers when Git release tags are pushed. The release tag regular expression can be set in the configuration file.
NAME = 'release_job'[source]
manage()[source]
Module contents
Manage the CI file.
class prometa.git.gitlab.ci.CIJobManager(gitlab_ci)[source]
Bases: Registrable
NAME = None[source]
Parameters:
manage()[source]
class prometa.git.gitlab.ci.GitLabCI(host, path='.gitlab-ci.yml')[source]
Bases: object
Wrapper around the gitlab-ci file.
__init__(host, path='.gitlab-ci.yml')[source]
Parameters:
  • host – A GitLabHost instance.
  • path – The path to the gitlab-ci file, relative to the repository root directory.
add_stages()[source]
Add the list of stages for all added jobs.
add_tags()[source]
Add runner tags. This will deduplicate tags and also ensure that jobs using the same tags reference each other in the YAML output.
property data[source]
The CI configuration data.
get_ci_job_manager(name)[source]
Get an instance of the named CIJobManager subclass.
load()[source]
Load the file data.
Returns:
The loaded data, or an empty dict if the file does not exist.
manage()[source]
Manage the configured jobs in the CI file.
property project[source]
The Project instance or subclass.
